BATTERY TOOLBOX    ·     ESTIMATE BATTERY LIFE WORKFLOW
Estimate your device’s battery life — without waiting for a real one to drain.
Combine a real measurement of your device with a battery profile and get a defensible runtime number, in seconds. Compare batteries, test “what if” firmware changes, decide before you commit.
HARDWARE
Otii Ace Pro or Otii Arc Pro
SOFTWARE
Otii + Otii Battery Toolbox
The Battery Life Estimator combines two profiles — one of your device’s power consumption, one of a battery — and predicts how long the pairing will run. Measure your device, then test any battery against it and get an answer within seconds.
Work flow, end to end
STEP
01
Measure the current profile of your device
Connect your device to an Otii Arc Pro or Ace Pro and run it through a representative usage cycle — wake, transmit, sleep, repeat. Otii captures every state at high resolution.
The richer the cycle you capture, the more accurate the estimate. Depending on your use case, a few minutes of real behaviour is usually enough to cover all the device states.
STEP
02
Optimizing battery life of IoT devices
Create a device profile from the measurement
Mark the segments of your recording that represent each device state — sleep, active, transmit — and the Estimator turns them into a device profile.
Adjust the duty cycle of each state to model different usage patterns: a sensor that wakes once a minute vs. once an hour, for example.
STEP
03
Configure a battery from an existing battery profile
Pick a battery profile — one you created with Profile & emulate, or one provided to you. Set the number of cells in series or parallel and the starting state of charge.
Want to compare three batteries? Configure each as its own scenario in the same project.
STEP
04
Run the estimator
Run the simulation. The Estimator combines your device’s load with the battery’s discharge characteristics — voltage drop, capacity, internal resistance — and returns a predicted runtime, plus a discharge curve you can export.
Change a parameter (different battery, different sleep duty cycle, different temperature assumption) and re-run instantly. No new bench time required.
WHEN TO USE THIS WORKFLOW
Battery selection
You’re choosing between vendors or chemistries and need apples-to-apples runtime numbers under your real load — not datasheet conditions.
Firmware “what-if”
You want to know how much battery life a new sleep strategy or duty cycle will buy you, before you push it out.
Customer commitments
You need a defensible runtime number to put in a datasheet, RFP response, or product spec — backed by your device’s actual measured behaviour.
Get a battery life estimate this afternoon.
Start the Battery Toolbox free trial on your Otii hardware. Or book a demo and we’ll run an estimate together.
