What is the purpose of general purpose output pins in Otii Arc?
October 31, 2018
You asked us what kind of load can be connected to general purpose output GPO1 and GPO2 pins in Otii Arc expansion connector.
They are controlled via scripting and can be used for automation, we actually use them ourselves to control parts of our production test equipment.
The voltage is set by digital voltage level in the supply tab in project settings and the maximum sourced current or sinked current is 10mA per pin.
