AAA battery testing made easy with Otii Ace Pro and Otii Battery Toolbox
November 24, 2025
Many engineers and developers working with IoT devices suspect that their products suffer from poor battery lifetime, but they don’t know how to begin addressing the problem. They view battery testing as complicated, time-consuming, and requiring expensive and extensive lab setups.
The truth is, while batteries can be complex, testing with Otii Ace Pro and the Otii Battery Toolbox is easy. You can create battery profiles, validate performance, and gain insights into how your devices behave under realistic conditions, without being a battery expert.
This article provides a practical example: testing five brands of AAA alkaline batteries under various discharge conditions, demonstrating how Otii simplifies the process.
What we tested
We selected five standard alkaline AAA batteries, each marketed as a premium option for high-drain devices:
All batteries were discharged at 25°C in a temperature-controlled chamber (optional, but it removes environmental variations). They were not brand new, stored for 1–2 years, so some self-discharge had occurred. However, since all brands were treated equally, the comparison remains valid.
Why discharge methods matter
Most datasheets show only constant-current discharge curves, but IoT devices rarely consume power that way. Instead, they operate in bursts – active when sensing or transmitting, then sleeping in between.
To reflect this, we compared four discharge methods:
  1. Constant Current (25 mA) – The reference measurement
Otii Battery Toolbox setup for battery validation under the Constant Current option.
Otii Battery Toolbox setup for Battery Validation under the Constant Current option.
2. Constant Power (37.5 mW) – Equivalent to 25 mA at 1.5 V, but current increases as voltage drops
Otii Battery Toolbox setup for battery validation under the Constant Power option.
Otii Battery Toolbox setup for Battery Validation under the Constant Power option.
3. Pulsed 1 (30 mA / 20 mA alternating every 0.5s) – Average 25 mA, simulating moderate activity variation
Otii Battery Toolbox setup for Battery Profiling with Pulsed 1 (30 mA / 20 mA)
4. Pulsed 2 (50 mA for 0.5s / 0 mA for 0.5s) – Average 25 mA, simulating active/sleep cycles
Otii Battery Toolbox setup for Battery Profiling with Pulsed 2 (50 mA for 0.5s / 0 mA
For each brand and method, two batteries were tested. If one was clearly faulty, it was excluded from the evaluation.
The Otii battery testing setup
The setup was simple:
  • Instrument: Otii Ace Pro units connected to a PC (it can be either Windows, macOS, or Ubuntu operating system)
  • PC Software: Otii Desktop App with Otii Battery Toolbox license (Battery Validation + Battery Profiling)
  • Battery connections: Batteries spot-welded to metal strips (to reduce resistance), no holders used
Different brands of AAA batteries connected for profiling inside the temperature chamber.
Multiple Otii Ace Pro + Otii Battery Toolbox connected, validating and profiling AAA batteries
Otii in action
  • Battery Validation was used for constant-current and constant-power discharges. It allows fully customizable discharge patterns, including complex pulse trains or even cycling tests for rechargeable batteries.
  • Battery Profiling was used for pulsed discharges. It alternates between high and low loads, calculating internal resistance and open-circuit voltage during the test. Results are stored in a battery profile file that can later be used for analysis or even for battery emulation.
Discharge was stopped at 0.75 V, a typical cutoff voltage for alkaline batteries. With capacities around 1100–1400 mAh, each test ran for 40–60 hours.
The results
The measured capacities (average of two batteries per case) are shown below:
ManufacturerConstant Current 25mAConstant Power 37.5mWPulsed 1 (30/20mA)Pulsed 2 (50/0mA)
GP1.358 mAh1.234 mAh1.351 mAh1.344 mAh
Varta1.240 mAh1.158 mAh1.245 mAh1.232 mAh
Panasonic1.106 mAh1.045 mAh1.110 mAh1.118 mAh
Energizer1.179 mAh1.137 mAh1.211 mAh1.185 mAh
Duracell1.211 mAh1.144 mAh1.199 mAh1.198 mAh
Battery profiling results obtained from Otii Ace Pro + Otii Battery Toolbox for Pulsed 2 (50mA for 0.5s / 0mA for 0.5s) validation
Constant current vs constant power
As expected, constant power was tougher on all batteries, since current rises as voltage falls. Capacities dropped by 4–9% compared to constant current.
ManufacturerCP/CC Ratio (%)
GP91%
Varta93%
Panasonic94%
Energizer96%
Duracell94%
Pulsed vs constant current
For IoT-like pulsed loads, results were very close to constant current. With the moderate pulses used here, capacity differences were within ±3%. Stronger pulses would likely show bigger effects.
ManufacturerPulsed 1 / CC (%)Pulsed 2 / CC (%)
GP99%99%
Varta100%99%
Panasonic100%101%
Energizer103%101%
Duracell99%99%
Battery testing doesn’t have to be intimidating. With Otii Ace Pro and the Otii Battery Toolbox, you can quickly set up tests, create battery profiles, and validate performance under realistic conditions for the specific use case.
Instead of relying solely on datasheet curves, you can observe how your batteries perform under your device’s usage pattern. Otii simplifies the testing process, making it straightforward and repeatable. This lets you focus on improving your product’s battery life rather than struggling with complex test setups.
You want to know how to perform battery testing with Otii Product Suite? Book a demo with one of our product specialists.
